dracutaco
- Nov 7, 2004
- dracut ma/bethlehem nh(weekends)
ok i have seen posts regarding light show before but with 7000 miles this is the first time i have seen it. my question is the only one sparking is loose fitting to spark plug. i pulled the wire off and did see alot of carbon or black dust inside the spark plug boot. was wondering if there is a fix for this problem or is the boot itself junk. i cleaned it off and put it back on and the light show went away but the connection is still loose. thanks for your input.
If I remember correctly you can clean the boot with that electric aresol cleaner then use dielectric grease and reinstall. If this does not fix the light show get new boots.
Convert
- Apr 14, 2003
- Lakeville & Nevis, MinNoSnowta
Sled Dog said:If I remember correctly you can clean the boot with that electric aresol cleaner then use dielectric grease and reinstall. If this does not fix the light show get new boots.
Ditto
dracutaco
- Nov 7, 2004
thanks
thanks for the response,after i cleaned the boot the light went away but the boot was still loose so i didn't know if i should do anything for that. but i will put the grease. thanks again
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Re: thanks
Sorry its not stock with all those mods you listed,but 112 is preety good though.dracutaco said:thanks for the response,after i cleaned the boot the light went away but the boot was still loose so i didn't know if i should do anything for that. but i will put the grease. thanks again
srxpert
- Apr 30, 2005
- Pembine wisconsin
- 2014 viper
repair
if you have loose spark plug caps order yamaha part number 8fa-82310-01-00.this is the newer spring clip,should fix the problem.good luck.
rage man
lol
rx1mtn
srxpert; is this a coil clip or plug end? I have read somewhere that there are new coils to tack care of this problem, part # 8ES-F3711-00-00
srxpert
- Apr 30, 2005
- Pembine wisconsin
- 2014 viper
clip
it is my understanding that it is a new cap that goes on the coil.i found this out in the september issue of snowtech,page 38.i havent checked with yamaha to confirm but i will today.
dracutaco
- Nov 7, 2004
love this site
this is why this site has gone sofar, the people on here are very helpful and have no problem with giving advise, thanks to all for your responses and the part numbers supplied
03griz
Has anybody looked any further into this to see what this new part number is exactly and what are the results?
Len Todd
Page 38 of Sept 2006 Issue of Snowtech
Part #8FA-82310-01-00 replaces the "COIL CAPs that have a revised style spring clip."
I will probably not need these. YES put 4 new coils on my 04 Rx-1 at the end of last season. Knock on wood!
