scuba335
- Dec 8, 2007
- Boston, MA
- 2025 Sidewinder LTX-LE
Has anyone swapped the OEM heated seat switch with a lighted one?
- Nov 29, 2009
- sabattus, maine
This was discussed before and I don't think anybody came up with a good option. I think the issue was the switch itself is the resistor to control high and low. Could be wrong about that though. But maybe keep the stock switch and wire in a seperate LED after the switch?
lilrez
- Feb 7, 2016
- Near Ottawa
Following.
Something i was considering tinkering with.
scuba335
- Dec 8, 2007
- Boston, MA
scuba335
- Dec 8, 2007
- Boston, MA
I ordered higher resistance resistors (3.9k and 4.7k) as the stock low setting can be too hot and ordered a new rocker switch body with 2 red LEDs and an etched switch cover. To make it work I'm going to take 12v power and neg from the seat connector on the main harness side and bring it to the new switch to supply the power for the backlights. It should light up low when on the low setting and high on the high setting. I will post a picture of the switch and how it's wired.
lilrez
- Feb 7, 2016
- Near Ottawa
Interesting. Would have though high setting was direct. Did you happen to measure voltage at seat plug ?
scuba335
- Dec 8, 2007
- Boston, MA
scuba335
- Dec 8, 2007
- Boston, MA
scuba335
- Dec 8, 2007
- Boston, MA
lilrez
- Feb 7, 2016
- Near Ottawa
Awesome job.
scuba335
- Dec 8, 2007
- Boston, MA
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Cool!!! (or hot should I say?)
Very nice. Thank you
snow_rider
- Apr 2, 2009
- Tawas City MI
- 2018 Sidewinder LTX-LE 50th
Thanks as well, very nicely done!
Are the resistor values in your switch diagram the new values?
If so, do these now make what the factory low felt like the new high setting, then low is more like a normal low that you can leave on?
(I agree, the factory low was way to hot, and couldn’t even use the high setting!)
Also, where did you get the new switch?
Steve
Steve
