Have you tried the dealer? Part #8ET-47495-10-00. Not cheap at $45CAD each though. Maybe check with Royal Distributing for an aftermarket piece that would work. I think there's even universal ones. Be sure to use two of them because if the one breaks, it will destroy your front shock (ask me how I know).
As a former owner, going from memory:
- steering slop from worn ball joints, A-arm bushings, tie-rods and linkages, worn bushings in ski spindles
- exhaust donuts, cracked Y-pipe under tank
That's all I can remember apart from other normal stuff.
