Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Agree. It's not 2 mins for me, but 10 and it's out. Easy.I like shagnos technique better..
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Doing this tomorrow after some testing stock on the gun...
So easiest to remove PTO side charge tube ....remove entire tube altogether or just the inside clamp? can then reach under to get at ecu? I will post up pics tomorrow when I do it here.
thnx gang
Dan
thnx gang
Dan
TurboWinder
- Jan 15, 2017
- Plainfield IL
- 2017 Yamaha Sidewinder
I just pulled the charge tube from the air box and disconnected the blow off valve and was able to get me hand in there. Its tight but not to bad.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Mr Oz, I would love to see you pull that ecu in 2 min.
Challenge accepted! I couldn't do it 2 minutes
Mr OZ or Shagnos or whoever you are today. Nice job!
WINDER1987
Great video!! Does anyone have a video of where they relocated there's too?
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Why relocate? It's so easy already.Great video!! Does anyone have a video of where they relocated there's too?
WINDER1987
I thought you relocated yours already lol I saw some pics a while ago on it but can't remember where
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
I just removed the clamp on the l/h charge tube and pushed it out of the way then just pulled the Ecu out after unhooking the rubber strap. Took less than 2 minutes.
Ya, ya, but you probably have girly hands. LOL Thanks for the great idea.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
You WIN! LOLChallenge accepted! I couldn't do it 2 minutes
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Just did some work today on Toms SW.....Got the ECU removed and boxed up ready to be shipped out tomorrow AM to Ben. Also pulled the secondary and found one roller with flat spot, got HAUCK rollers coming soon, Got some shim washers ready for helix. Got a GGB proto exhaust here to test with and got Bens SQ coming too.
Gonna be a fun week! Working on the Yam clutches are a pleasure I have missed since apex days, removing rollers is so simple its hard to believe cat and doo rollers can be such a nightmare when you work on such a nicely engineered secondary.
Dan
Dan
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
LMAO!!! Small hands = large schlong....!! LOL. It helps I have been wrenching professionally for almost 40 yrs.Ya, ya, but you probably have girly hands. LOL Thanks for the great idea.
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
Great clip! Was so pumped after seeing this, I tried the same. 15-20min later the beast is out lol. Cant wait to get it back in post flash lol (have no idea how that's going to work - from hands to forearm clearances it was super tight).
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I hear ya....I have to wonder if the rubber band was already removed on his video?? hahaGreat clip! Was so pumped after seeing this, I tried the same. 15-20min later the beast is out lol. Cant wait to get it back in post flash lol (have no idea how that's going to work - from hands to forearm clearances it was super tight).
I was hoping the rubber band had the little handle on it like the apex tool kit rubber band used to have, no such luck so its abit tricky to unhook it!
I removed more items mostly cause I wanted to see this machine and how things are routed, and also when I have to reinstall ECU and plug it back in I think it will be alot easier to install with some items removed.
Dan
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
Ok...I've greatly improved my timing. Approx 5 min getting my hands/arms down in there to place and reconnect the flashed ECU (while Shagnos goes elbow deep in seconds lol) and another minute or so playing with the rubber strap). Done in 6 minutes flat lol. Cheers!
