![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
Great clip! Was so pumped after seeing this, I tried the same. 15-20min later the beast is out lol. Cant wait to get it back in post flash lol (have no idea how that's going to work - from hands to forearm clearances it was super tight).
Ok...I've greatly improved my timing. Approx 5 min getting my hands/arms down in there to place and reconnect the flashed ECU (while Shagnos goes elbow deep in seconds lol) and another minute or so playing with the rubber strap). Done in 6 minutes flat lol. Cheers!
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
You're gonna really love that stage 0 flash..should make sled run better with the exhaust.Ok...I've greatly improved my timing. Approx 5 min getting my hands/arms down in there to place and reconnect the flashed ECU (while Shagnos goes elbow deep in seconds lol) and another minute or so playing with the rubber strap). Done in 6 minutes flat lol. Cheers!
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
You're gonna really love that stage 0 flash..should make sled run better with the exhaust.![]()
Can't wait amigo. Priceless
Shagnos
Everything was there. The band is vertical so you press it against the Ecu and push down. It stretches and the metal loop falls off the hook . Now you just have 2 buttons to push to release the plugs. I spent more time maneuvering it to get it out. That was my 2nd time so with more practice I bet I could shave off 10 seconds. LOL The socket stuck on the clamp was not expecting that and wasted time. That was gravy compared to some under dash stuff.I hear ya....I have to wonder if the rubber band was already removed on his video?? haha
I was hoping the rubber band had the little handle on it like the apex tool kit rubber band used to have, no such luck so its abit tricky to unhook it!
I removed more items mostly cause I wanted to see this machine and how things are routed, and also when I have to reinstall ECU and plug it back in I think it will be alot easier to install with some items removed.
Dan
I said I have wrenching for a living for close to 40 yrs. Back in the 80's getting paid book I would pull a Turbo 350, disassemble, have the case in a spray cabinet and be starting to rebuild in less than 1 hour.
Shagnos
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Ahhh....I think you must been heated shop. Rubber band on mine out in cold shop was not very stretchy, no way could stretch it as you were able to....Had to get a pick tool onto the metal end clamp and get it to release the rubber band off...grrrEverything was there. The band is vertical so you press it against the Ecu and push down. It stretches and the metal loop falls off the hook . Now you just have 2 buttons to push to release the plugs. I spent more time maneuvering it to get it out. That was my 2nd time so with more practice I bet I could shave off 10 seconds. LOL The socket stuck on the clamp was not expecting that and wasted time. That was gravy compared to some under dash stuff.
Dan
Shagnos
Dan
Yep it was heated. ok I'll allow 6 more seconds for a cold strap.....LOL
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
When its cold it wont stretch easily at all, so you will add alot more then 6 seconds! LOLYep it was heated. ok I'll allow 6 more seconds for a cold strap.....LOL
I messed with that strap for awhile, trying to get a tool on the hook end...grrr
haha
Shagnos was raised on a farm, that's why he is able to ram his hands and arms deep into the sidewinder. Removing the ecu is like birthing calves! I'm still in shock he went that deep without any protection!
Shagnos
![Hide :hide: :hide:](/styles/default/xenforo/smilies/hide.gif)
![Moon :moon: :moon:](/styles/default/xenforo/smilies/moon.gif)
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
LOL!Challenge accepted! I couldn't do it 2 minutes
WINDER1987
Any updates to this after a year or tips I still think this is a pita to do and to get to lol
krm
- Apr 22, 2016
- ny
Remove the drive clutch ,it makes it much easier .Work from the side .
31cccat
I take off intake hose
Can put your arm down in there easy and apply pressure down to middle of the rubber strap and as stated above loop falls off bottom hook
theewarrior
Less them 2 minutes
