Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Guy's
I added a sled related tech info page to fourstrokesolutionsllc.com. The idea is to post some tech info not usaully found in service manuals.
So far I have driver diameter specs, some rear skid weights, and mounting points for the rear skid in a Nytro XTX.
I'm looking for some more skid weights (OEM or aftermarket) and MTX tunnel measuring points.
http://fourstrokesolutionsllc.webs.com/ ... edtech.htm
http://fourstrokesolutionsllc.webs.com/ ... =112128969
Thx
Bill
Thx
Bill
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
2010 MTX 162 skid all factory wheels and scratchers 58.5lbs.
2010 IceAge rails, Timbersled suspension, Whal anti stab 4 wheel kit, slidekicks, Timbersled 2 wheel kit, Timbersled upper wheels, with slides is 34.6lbs. With Exit shocks, piggy back front(4.3lbs) and remote resi rear(7.0lbs) is 45.9lbs.
Used a digital hanging scale just calibrated.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
tapex_07 said:2010 MTX 162 skid all factory wheels and scratchers 58.5lbs.
Cool I will add it in, thank tapex_07
hugger70mtnmax
Just used a 153 cat float skid minus the bogie wheels with scratchers and it was 43lbs.
Mtnviper
- Aug 19, 2003
- Burlington Wa.
hugger70mtnmax said:Just used a 153 cat float skid minus the bogie wheels with scratchers and it was 43lbs.
Added in, thanks hugger70mtnmax!
LoneViper
Nytro 153 Pro Mountain with all wheels, shocks and factory drop brackets;
78 Lb 11 oz. Front shocks,4Lb each.
Timbersled complete with Yamaha 153" rails, Timbersled drop brackets, and Fox float 2 front shocks; 46Lb 3oz
Mtnviper
- Aug 19, 2003
- Burlington Wa.
LoneViper said:Nytro 153 Pro Mountain with all wheels, shocks and factory drop brackets;
Got it, thanks LoneViper!
Did you mount it as a 153 or set it back to a 162?
hugger70mtnmax
I actually have it in a mountain max set back for a 159. I have another one to go in the nytro that is a 162 that I will run with a 162 camo extreme.
- 54K
