Loose A-arm bolt!!!
Yamacat21
Cloquet, MN
i bent an a-arm on my 2014 ltx se. when I pulled the nose piece off to access the bolts I found the bolt for the other are had backed itself almost all the way out of the nut. Might be worth a check, takes five minutes and a t-20 to take the panel off.
Thanks, adding to my list, engine is out of the sled and since I’m waiting for parts I think I’ll go through all the bolts with some blue locktite.
I did a post on this last year, when I bought my sled used I was doing some maintenance and found that ALL the bolts on the frame soars had rattled loose! 1/2hr job if you are already in there to Loctite the nuts. Made the sled way more stiff.
