07 GT
I was just doing a inspection on the skid of my 07 GT and I noticed the hyfax will move left to right towards the rear of the skid!
I have oem slides on there. Are they supposed to be that loose? Im afraid if the screw that holds them on breaks, the slide will come out and ruin the track or worse.
big guy
If your hyfax is moving that much the screw is probably already broken? You better check that very carefully!
Here is a link to Rocker Dan's fix for it. Scroll down till you see pics of his Hyfax fix.
http://www.ty4stroke.com/viewtopic.php?t=78847
07 GT
Thanks.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Run your hand under the hyfax as it may be split. The front screw would have no effect on side to side movement except towards the front. A little side to side movement is normal though. There should not be any up and down movement.
mud99
The side to side movement itself is fine, the Ice Age rails I run have a very loose hyfax, makes changing it much easier.
HOWEVER, the Yamaha rails are normally very tight, so I would make sure you haven't tweaked something or split your hyfax, because you might have just found a symptom of another problem.
Mark
Mark
