loose track
jaykat
CT
I have a RTX and I only rode it a few miles and the track seemed to loosen and when I get on the gas it seems to slip on the sprocket. Does anybody know if this is normal and if I can just tighten up the track with the two adjuster screws !!??!!
The track on my Attak was very loose also. I tightened it up quite a bit and added a little bit of weight transfer to the rear and it would still ratchet. I had to adjust the weight transfer to "STD" or less in order for it not to ratchet but I had little hook-up out of the hole. I'm wondering if it is possible for my track to be "too tight"???
Track loose
My attack also loosened very much with only 40 miles. I bet that I turned the adjuster nuts on the track at least three complete turns to tighten it up again.
