lost hand and thumb warmer display
spadmaxx
sudbury ontario
04 rx1 when i start my sled hand warmer display works after display switches to fuel level meter and i toggle thumb warmer or now even hand warmer, display in cluster does not change over . but i have heat coming from grip heaters just no way to tell how hot they are any help would greatly be appreciated
Any fix for this, seeing same thing myself..
Check the wire harness in the nose of the sled. The wires rub on the aluminum bulkhead where they pass through. I had problems with my 04.
Thanks... I have continuity from the harness plug to the thumbwarmer....both wires
The ECU controls the display and function of the hand and thumb warmers. Check the plugs for corrosion. You can also reach out to Rockmiester. He is very knowledgeable about issues like this. And a very good guy.
