Jruggs73
- Jan 14, 2018
- Iowa
- 2017 LTX-SE
Hi everyone-Hope you are all doing well. I need some advice an my 17 LTX SW. Last season before my last ride and accident I installed a rear wheel kit from Yamaha. Before the kit install I was hitting 115-117 on the speedo. Last week on the same flat lake with great conditions I could only get 105. Will this kit take any top end off? I have 1,000 miles on the sled and need new hyfax which I ordered. Track tension and belt are within spec. I’m thinking about pulling the kit and see if it helps on my next trip. Anyone have any advice for me? Thanks in advance.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Check your clutch rollers. Possibly you knocked your engine out of alignment?
I highly doubt the extra wheels caused a loss in top speed.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I agree..... extra friction should scrub top speed. I had similar thoughts last year when I hit a brick wall at 110mph. After fourth wheel kit installed.
Today I pulled 120mph (speedo) with four wheel kit. Kinda last thought on the pull. Tomorrow I will be more intentional.
But agree, you shouldn't go faster with it. Idk.....
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I don't see it being the wheels either. Look elsewhere.
Speed is very condition dependent!
Jruggs73
- Jan 14, 2018
- Iowa
- 2017 LTX-SE
Mototown
- Sep 11, 2018
- Apex 40 th
I believe the 17 s the rollers should be replaced under warranty. 18 have updated rollers
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Yes Definitely part of problem, clutching is everything!
kuvasz
check your primary rollers as well. i got 644km out of mine.
