Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
hello I have a boosted apex 06 with an 09 engine took a compression test and 3 holes are 120 the 4 hole is 60 it's supercharged with head shim ,bigger injectors , aftermarket fuel pump running 12 pounds of boost rings look fine but that cylinder looked carboned up or sooted up at top edge of cylinder and also valves look black on that
Cylinder going to get piston measured for out of round and install new rings of measures good maybe rings are done from being boosted all the time
Any thoughts suggestions?
Bad valve or maybe head gasket would be my gas.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
When did you do a compression test? After it has been sitting since last season? Was it running fine last time you rode it?
Or was it running poor and you did his compression test to start troubleshooting?
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Thanks I will check the valves on that cylinder head gasket looks goodBad valve or maybe head gasket would be my gas.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Hi ever since I started this project I have always had trouble getting the afrs at an idle to show any numbers like it was pouring to much fuel in but when driving it was good tons of power just at an idle it smelled like to much fuel no matter what I did with the programmer so I decided to do a compression test and the one cylinder was at 60 other three at 120 so I figured that was the problem compression down on the one cylinder and with it being boosted it made up for the low compression with the extra air being forced in , I never took a compression test before thisWhen did you do a compression test? After it has been sitting since last season? Was it running fine last time you rode it?
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
The reason I was asking is after my Apex sits a season, the cylinder leak down is horrible due to the valves corroded at the seats until it is started and run for a bit. But this is obviously now not that case, since you have an issue running too.
I'm with MrSled, I think the problem lies with the valves in that cylinder, leaking and not sealing. If you had piston damage from boosting that is causing that low of compression you'd have piston crown damage from detonation, eroded away to the first ring land. It's not the piston or cylinder.
How many miles on the valves or since last clearance adjustment?
Start with bolting the cam's back in the head and checking the clearances... likely have a valve that is seated in enough to not have any clearance and is staying slightly open, hopefully it's just as simple as changing to smaller lash pill under one of the caps.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
hi and thanks ,yes i was doubtful on the piston as soon as i pulled the head off the cylinders looked like new yet and all pistons looked good from the top side but i decided to pull that piston out that was down on compression and rings and piston all looked perfect also
as far as the miles on the last valve adjustment i have never done it and not sure if previous owner has ever done it either but i am definatly going to check that out also
will bolt the cams in and do some checking and measuring
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Make sure you don't have a broken exhaust valve spring, too.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
For future reference you should have performed a cylinder leak down test before you tore in to the engine. If you have a low cylinder during a compression test a leak down test will guide as to weather it's leaking past the rings or intake or exhaust valves. Always a good idea to check valve clearance before tear down.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Okay thanks I will check that alsoMake sure you don't have a broken exhaust valve spring, too.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Okay thanks good to know I will know better for next time will purchase a leak down tester alsoFor future reference you should have performed a cylinder leak down test before you tore in to the engine. If you have a low cylinder during a compression test a leak down test will guide as to weather it's leaking past the rings or intake or exhaust valves. Always a good idea to check valve clearance before tear down.
mryamaha
So what was the verdict on this one??
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Well I checked the cylinder that was low and the cylinder looked good piston ,rings all look good ,I then checked the cam shaft clearance and the valves on that cylinder are needing a valve adjustment they are to tight so will change the pills on those that was the intake valves, I then turned the head upside down turned the cams till valves were closed on that cylinder took isopropyl and dumped in where the valves seat and it sat in there all afternoon never went down so valves must be seating wellSo what was the verdict on this one??
So I will put it back together reset valves and hopefully all goes well
