Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
hello I have a boosted apex 06 with an 09 engine took a compression test and 3 holes are 120 the 4 hole is 60 it's supercharged with head shim ,bigger injectors , aftermarket fuel pump running 12 pounds of boost rings look fine but that cylinder looked carboned up or sooted up at top edge of cylinder and also valves look black on that
Cylinder going to get piston measured for out of round and install new rings of measures good maybe rings are done from being boosted all the time
Any thoughts suggestions?
