KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
That'll do it. Now to question where this #*$&@ came from and what it is.
2 Questions:
1. What brand and weight of oil do you run?
2. Do you let the engine cool for a minute prior to shutting it off so it doesn't coke the oil in the turbo from the extreme heat?
Turboflash
- Mar 18, 2019
- Southern MN
He uses Yamalube oil & filters.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Mirroring the earlier comment. I had issues with the oil tank seal so I had the tank apart twice in five years. I was surprised how much was deposited in the bottom of the tank. This is after using amsoil and meticulously changing oil and filters year in and out. Replacing that oil tank seal every 4-5 yrs may be a blessing in disguise. My screen was in reasonable shape but had some debris on it.
Ms
Ms
McKabe
- Dec 13, 2020
- Marenisco, MI
- 2018 Sidewinder ltx dx
This sled has had yamalube with oem filter since new.
Drained the oil again and found a few more bronze chunks. I'll have the motor out this week for disassembly.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Yamaha has some kind of warranty on there oil if ist always used since new! Don't know if they ever pay out but you might want to look into it!
www.yamaha-motor.ca
Yamalube Advantage - Yamaha Motor Canada
Turboflash
- Mar 18, 2019
- Southern MN
Bronze chunks? NFG. I'm trying to think about where bronze is inside 998. Main bearing material? Connecting rod material? Don't think oil pump has anything. ????This sled has had yamalube with oem filter since new.
When I was a bush pilot/aviation mechanic back in the radial engine days we always pulled the oil screens every 50 hour inspection.
Brass in the oil screen beyond a slight trace was always an engine change.
