Fleecer
- Jun 13, 2014
- 2019 SRX
So what ended up being the issue?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Still not sure about a boost leak yet,but what happened to make the biggest help,was the redrilling an extra hole in the drop bracket of the rear tunnel. Sense it is a MTX tunnel,and the holes drilled in it,are for the extra long tail and track,which we don't have,so after drilling a hole 1" higher into the drop bracket,and doing set up,it dropped the rear bumper 2" wow,we needed that,but what we stumbled onto,was by doing this,it tentioned the track,just by doing that,now we got two for one lol. and now no more racheting,and now transfers,but we still didchange the transfer blocks yet more,removed them,and now Wow! Hooks and books.So what end ended up being the issue?
Zr900turbo
- Jan 22, 2019
- Norway
- Norway
- King cat
Did you find out what the rpm problem was?Still not sure about a boost leak yet,but what happened to make the biggest help,was the redrilling an extra hole in the drop bracket of the rear tunnel. Sense it is a MTX tunnel,and the holes drilled in it,are for the extra long tail and track,which we don't have,so after drilling a hole 1" higher into the drop bracket,and doing set up,it dropped the rear bumper 2" wow,we needed that,but what we stumbled onto,was by doing this,it tentioned the track,just by doing that,now we got two for one lol. and now no more racheting,and now transfers,but we still didchange the transfer blocks yet more,removed them,and now Wow! Hooks and books.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes,way back than we had several problems,they have now been ironed out,the exhaust leak was fixed and was part of the problem,now things are back to where they should be. ThanksDid you find out what the rpm problem was?
