wot-75
I put about 80 miles on yesterday in the Two Harbors area of North East Mn. They just got over 2 feet of snow so conditions were near perfect both on and off trail. We had a stock Nytro and a couple Polaris Rush Switchback Pro R's for comparison.
My LTX is a base model running Fox Evol X shocks.
Accessories include Skinz Console Pads, HID 5K headlights, Skinz front bumper, and SLP Powder Pro's with 6" Carbides.
Previous Sled: 2012 Polaris Switchback Pro R
Ergonomics: I'm 5'8"/215lbs and found the ergo's to be perfect whether standing, sitting upright, or leaned over the sled in corners. Knee pads are a must have for this sled as your knees are constantly touching the panels no matter what riding position you're in.
The following assumes aggressive trail riding:
Handling: This is subjective since I obviously have upgraded shocks but they are probably pretty close to how the FF3's on the SE models will perform.
General: HEAVY! specifically in the front. The weight difference is immediately noticeable between the 2 stroke and the Viper. You will work harder to ride this sled fast/aggressively because of the extra weight.
Straightline: This is where the extra front end weight helps IMO. It's very confidence inspiring as it feels firm and planted while blasting down the trail.
Flat/banked corners: Very little inside ski lift (none on banked corners) and one of the reasons I feel this occurs is because of the Ripsaw 2 track characteristics and how they interact with the chassis (more on that later)
Off camber corners: noticeably more ski lift however mostly fixable with technique/suspension adjustment. The sled's extra weight is not doing you any favors here but the right handlebar inputs, throttle controls, and the RS2's tendency to slide seem to correct this pretty quickly.
Woops and those "oh crap that's a deep hole I'm about to land in" moments: I couldn't be happier with this sled's ability to soak up those hits. It also performed well during the times when I jumped from one woop and landed ski-first into the face of another woop. It could be the Evol's I'm running contributing to the sleds ability to stay composed during these moments.. but every time I encountered this situation (scared!) I came away with "well that wasn't so bad no was it?" comment to myself. This was a concern with me considering how much front weight bias this sleds seems to have.
Ripsaw 2 Track: I'm used to riding a 1.352 Cobra on the Switchback. The thing that I absolutely love about the RS2 is it's tendency to slide latterly on corner entry and then how it transitions from sliding to hooking up on corner exit. This gives you the feeling of steering with the rear which is pretty amazing considering how heavy the sled feels in the steering department. The Cobra on the Polaris always felt like it just wanted to drive you in whichever direction the sled's momentum was going and not where the ski's where pointed if that makes sense.
The only negative I have of the track is that it sucks in deep loose snow. It's VERY quick to trench down and the extra weight of the sled doesn't help here whereas the Polaris/Cobra combination seemed to love the deeper more powder-like stuff. Case in point, we turned around on the trail which required everyone to pull 90 deg left into deeper snow, back up, and then scoot back the other way. The 2 Polaris' with Cobra's did this with no problem. I got stuck trying to back up and stuck again after we lifted the tunnel out and moved it 45 degrees back on to the top of the deep snow. I had to completely pin it and rock back and forth to get it out.. with other people pushing to boot. Not fun!
Side Notes. This sled responds well to aggressive inputs. It seemed like the harder I rode it the better it felt... which also meant that the harder I rode it the more worn out I got.
So far I am happy with my purchase!
