Janne339
Anyone running this? Never heard of that before?
https://www.magnumtuning.com/en/det...ed-rev-limiter-cdi-box/yamaha/sr-viper-xtx-se
Mine has PCV with ignition and RevExtend. I dont need the Rev Extend since mine makes most MPH at lower than stock RPM limit. Turbo guys well they seem to make more mph the higher they rev the thing. Sounds like you still need a fuel tuner so I would recommend getting a system or just a flash.
Alsim
- Oct 6, 2014
- LTX SE 2018
Yes mine have Evo stage 4 that is raise limiter to 9800 but no gain over 9000- 9100. The clutch is not efficient at highest rpmMine has PCV with ignition and RevExtend. I dont need the Rev Extend since mine makes most MPH at lower than stock RPM limit. Turbo guys well they seem to make more mph the higher they rev the thing. Sounds like you still need a fuel tuner so I would recommend getting a system or just a flash.
Studroes144
Same thing I've seen. Engine hp may go up beyond the stock rev limiter but clutch efficiency goes down. On lower boost best mine ran was around 9200, at higher boost it loves it at 88-8900.
