Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Every Yamaha owner must get the red fuel pump relay. I don't know why Yamaha would send all these sleds out with that crappy one that comes stock. My nytro Had a few days where it was -10 to -15 and it wouldn't start because the relay was frozen up. Couldn't imagine going on a trip somewhere overnight and then not having your sled start in the morning. SO MAKE SURE YOU ALL REPLACE THE FUEL PUMP RELAY WITH THE RED COLD START ONE! On the nytro I believe it's the 3rd one from the front end of the sled. It will save a lot of frustration!
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Easiest way is to start at the front. Put your hand on top of each one and turn the key with the othe hand. You will feel the correct one "click" under your fingers. Quick and easy
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
I got a 2012 nytro xtx, I switched the 3rd one so I hope that's right ahahIts not always the 3rd one depends on year. You can go by the wire color. See attachment
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Try out what I mentioned and you will figure it out quick lol
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Well I've been running it for like a month now, I think something would have not worked if it was the wrong oneTry out what I mentioned and you will figure it out quick lol
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
I still have the black relays in my sled. Last winter was record cold around here and I never had the fuel relay freeze. The headlight relay froze once, but once the sled was running for a couple of minutes it was all good.
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
You park urs in a warm garage or something?I still have the black relays in my sled. Last winter was record cold around here and I never had the fuel relay freeze. The headlight relay froze once, but once the sled was running for a couple of minutes it was all good.
pat4000
- Jan 12, 2011
- Pontiac QC
- Nytro xtx 1.75
I have 2014 nytro and mine is red ?
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
It is or what? Why the question mark?I have 2014 nytro and mine is red ?
Big_Phil
- Feb 5, 2014
- Sidewinder RTX LE
Ya in a garage most of the time. The garage is heated some of the time, only when im working on stuff tho. I was going to change the relay, but never had a problem so just left it.
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Well mine is never inside, so once I get moisture in that relay, it doesn't dry out, it just freezes. That's why it doesn't work, becuase there are moving parts in the black relay and they freeze not allowing them to work.Ya in a garage most of the time. The garage is heated some of the time, only when im working on stuff tho. I was going to change the relay, but never had a problem so just left it.
pat4000
- Jan 12, 2011
- Pontiac QC
- Nytro xtx 1.75
Just saying
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Ok, so Yamaha figured out that the other ones were crap finally lolJust saying
Matthew457
- Apr 6, 2015
- Peg
- Other
- Yamaha Nytro xtx
Is ur red one the third from the front?Just saying
