Skydog
Stock head gasket,HD studs, stock timming and fuel is not a problem! 115-120 octan what ever i need to run i will for max boost!
Thank you Skydog
Thank you Skydog
snowy1
I ran 18lbs on bone stock rx1 motor, with hd studs on strait vp110 at 10,000 ft no problems.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Skydog said:Stock head gasket,HD studs, stock timming and fuel is not a problem! 115-120 octan what ever i need to run i will for max boost!
Thank you Skydog
What Turbo??? Part number???
Blue shadow
What are you running or plan on running for boost?I am looking for a gt 28 RS To up my boost too.17 psi is just not enought anymore.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Blue shadow said:What are you running or plan on running for boost?I am looking for a gt 28 RS To up my boost too.17 psi is just not enought anymore.
I stock that turbo.
There is two different GT28RS one with a .84a/r turbine housing and one with a .64a/r turbine housing either one should sell for about $975.00
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
4kops said:There is two different GT28RS one with a .84a/r turbine housing and one with a .64a/r turbine housing either one should sell for about $975.00
Those days are gone, New Prices in effect Jan 07
Skydog
GT2560R The one we talk about Ted.
THank you
THank you
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Skydog said:GT2560R The one we talk about Ted.
THank you
GT2560R is part number 466541-1
GT2860RS is part number 739548-1
These two turbos are most popular for our sleds, the GT2560R is my favorite.
Skydog
So what can my motor take for max boost? If i run some big time fuel. I have HD studs every thing eles is bone stock.
Skydog
Skydog
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Skydog said:So what can my motor take for max boost? If i run some big time fuel. I have HD studs every thing eles is bone stock.
Skydog
There are a lot of variables but I am running 22 psi.
Skydog
What about with stock timming?
Thank you
Thank you
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Skydog said:What about with stock timming?
Thank you
Like I said lots of variables, email me tedj@jannettyracing.com
