Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
That about all I can do for today's exercise.Try the Dalton spring at 6-1, it’s worth a shot.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Conditions have a sh!t ton to do with speeds. Are you at Bent's? I'm sure the lake has a bunch of snow on it from last week and it's been fairly warm. I'm assuming some of these big speeds being posted are from ice or packed roads(i.e. optimum conditions). If you're running on a snow covered lake, my findings are that you will probably never get to overdrive. Just for sh!ts & giggles, go back and tighten all your boost hose clamps and don't forget the Turbosmart clamps.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Check your throttle cable as well to make sure you’re getting full throttle. Once these sleds have some miles, the throttle cables stretch. One year my sled was showing erratic RPMs and 1 psi low on boost on data logs, so I looked at throttle position and was only getting 88-91%. The throttle lever should not touch the bars at full throttle when freeplay is adjusted properly.
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Not sure if this will help since I am on a 129" sled but for what its worth:
TD Max 17
BOV upgrade
3 bar sensor
CAI
Ultimax Belt
Super quiet muffler
Thunder products primary spring with glide washers
Thunder products secondary spring
Dalton weights 74g
Secondary clutch machined to bring into spec and very clean with fresh rollers
8800 - 9200 rpm depending on conditions.
Last long pull 124mph@10 degree F, with some left. how much? don't know but still pulling hard when i lifted.
Doc Harley
- Oct 17, 2016
- Here & there
Wrapped Dalton Blk/Org to 6/1 seems to be hot. Still luke warm primary & belt.i see no signs of belt slip in sec.
Mph 116 @ 8900rpm
Marked primary, left behind about 1/4" of marker. Any thoughts?
Mph 116 @ 8900rpm
Doc Harley
- Oct 17, 2016
- Here & there
I'm close to Bent's. Lando. Temps are 30ish, snow is loose. Lake is a little rough.Conditions have a sh!t ton to do with speeds. Are you at Bent's? I'm sure the lake has a bunch of snow on it from last week and it's been fairly warm. I'm assuming some of these big speeds being posted are from ice or packed roads(i.e. optimum conditions). If you're running on a snow covered lake, my findings are that you will probably never get to overdrive. Just for sh!ts & giggles, go back and tighten all your boost hose clamps and don't forget the Turbosmart clamps.
Doc Harley
- Oct 17, 2016
- Here & there
Secondary pic
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
I’ve hit 127 gps. with stock gearing 21/41 at 9300 rpm’s! Out of gear!21/41 is good for 126 mph GPS. I've done it, and I don't think the sled was over 9000RPM
I think your speeds are right in line with your tune and gearing considering conditions.
Anything over 110mph GPS is freaking fast sled despite peoples claims. To get 116 you are already into overdive which is less efficient and robs hp as belt speed increases...1:1 is the most efficient.
I would bet if you could get your sled on a hard packed road or icy surface you would be running in the 120s.
It takes more and more hp per mile per hour over 100mph as the speed increases
On the GPS my Yamacharged Attak only runs about 106 or so on snow packed trails but will run 118 mph on a hard packed road...darn sled will just not hit 120mph!
Of course my SW is a different story.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Your belt appears to be shifting out into overdrive on primary and Luke warm is good. If your secondary is hot your belt is slipping and that slipping ( friction) is whats creating that heat.Wrapped Dalton Blk/Org to 6/1 seems to be hot. Still luke warm primary & belt.i see no signs of belt slip in sec.
Mph 116 @ 8900rpm
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
take your sec off, and take appart like you have, put back together with no spring, spread sheaves, turn belt inside out and push down in between sheaves and see how far you can push in... mark your sheave on top of belt while you push into sec. now put spring in clutch and compress it as far open as it will go.... do the same with the belt and see if its going in to the centre of hub or to the line you marked... if not then you have coil bind... if it does then sec is good...your sheaves dont look to be slipping... next,,,, with belt off ... compress primary and see if it closes sheaves right together with no coil bind... and test with belt to see how far it would travel up sheave once clutch faces are closed together if the belt looks like it would go further up sheave than what you mark shows then. to me it looks like your not getting full shift... which could be conditions for the power your at or clutchs are not allowing full shift
Doc Harley
- Oct 17, 2016
- Here & there
I'm working on this this morning.take your sec off, and take appart like you have, put back together with no spring, spread sheaves, turn belt inside out and push down in between sheaves and see how far you can push in... mark your sheave on top of belt while you push into sec. now put spring in clutch and compress it as far open as it will go.... do the same with the belt and see if its going in to the centre of hub or to the line you marked... if not then you have coil bind... if it does then sec is good...your sheaves dont look to be slipping... next,,,, with belt off ... compress primary and see if it closes sheaves right together with no coil bind... and test with belt to see how far it would travel up sheave once clutch faces are closed together if the belt looks like it would go further up sheave than what you mark shows then. to me it looks like your not getting full shift... which could be conditions for the power your at or clutchs are not allowing full shift
Thanks, Max
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
With the conditions you're testing on, the speeds you're running seem to be good. Rpms are good, try to get some of the heat out of the secondary, but I wouldn't change much. If you stick around this weekend you're going to get some really good air (cold/dry & she'll wake up a little more).
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
8JP and XS825 is not going to coil bind in the stock secondary period.
The pic shown is normal for Yamaha primaries. Putting a marker line on the clutches does not mean the belt is going there under power, it may be an inch down and when you let off the belt goes to the top. Never understood why people mark their clutches to see if the belt goes to the top. Its absolutely worthless to put a line on the primary and think the bets is traveling that far under power, the second you left off it then goes to the top.
Doc Harley
- Oct 17, 2016
- Here & there
Today is about 19°
Made two hard pulls to 100mph
Primary 150°
Belt 140°
Secondary 100°
Note: initial hit of the throttle and boost came up to 18psi but only held on momentarily. After a second or two boost dropped to 16.8
This is a little clearer then yesterday's info .
Lake has definitely become more challenging to hold a line.
Primary 150°
Belt 140°
Secondary 100°
