MBRP trail exhaust with OFT block off plate + C&A Ski bolt Question
Nytro-glycerin
Canada
2010 Nytro XTX Black edition
I ordered an OFT block off plate, with the cut out for the stock/OEM muffler. I just now ran into a deal from a friend on a trail MBRP exhaust. I am wondering if anybody has used this set up, and if the muffler will fit in the stock cut out on the block off plate? I know OFT makes a full block off for under tunnel which you can cut yourself, however I wish to be able to interchange the exhaust without having to modify or remove the block off plate!
Also, does anybody know if the stock ski bolts will work on a set of C&A XTX skis? Just wondering if ill need to pick up some new hardware (I didnt buy the mounting kit, just got the rubbers).
Thanks guys,
Cheers
I just installed a mprb trail can. Fits perfectly and sounds great. Not super loud but has a nice bark
