stone88
It's a 2014. I know the MCX 190 i had dynoed at Dynotech . And all the numbers were spot on as far as air fuel ratio. Was running 6 lbs of boost. Ran beautiful. Now with this extra hp. I ll have to add more weight in the clutching. Hoping to run 14-15 lbs of boost
If you don't mind me asking how much power did it make at dyno tech at 6#. I have the same kit and ran it at 15-16# on stock internals all summer on C-12 it was a beast with stock compression.
suburban
- Apr 19, 2003
- ontario
- 2021 SRX
it made 192.8 hp
stone88
it made 192.8 hp
Thanks I'll show this to my cat buddy who thinks I'm making 270 hp lol
machzrobbie
They use the 3 stock ones and 3 extras in the intercooler. Everything is pre-programmed and seems to run spot on.
I installed a walbro 255 pump on mine and its pig rich, had to take quite a bit of fuel out
DC5
That makes sense, that pump is probably able to keep up the fuel pressure.
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
With mine I have had problems with the fuel pump. Sometimes won't start when pointed down at a steep angle. Also have lot fuel on a climb. I have removed the fuel filter now.
machzrobbie
Yes I should have elaborated! I agree too, was just adding what I found when I added the fuel pump with the stock MCX map. I always push things so I wanted to be sure I have enough fuel - and I defiantly do!! Should be good for 30 pounds now!!
DC5
Now we just need some iceYes I should have elaborated! I agree too, was just adding what I found when I added the fuel pump with the stock MCX map. I always push things so I wanted to be sure I have enough fuel - and I defiantly do!! Should be good for 30 pounds now!!
Kritter1388
- Nov 30, 2014
- 2014 yamaha viper
It was 192 at 9000 rpm at 6 lbsIf you don't mind me asking how much power did it make at dyno tech at 6#. I have the same kit and ran it at 15-16# on stock internals all summer on C-12 it was a beast with stock compression.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
It is more of a fuel regulator problem above 6 pounds of boost. EVO has you remove the stock fuel pressure regulator and add an external one to run 15 pounds of boost.
Very interesting info here...
Yammie4life
running the 270 kit on my 15 XTX, all good, but not running to full potential, guessing same that was stated above, intake is under the hood. moving it to the outside when the intake comes for it... LOVE THIS KIT
CustomApexMan
- Dec 28, 2010
- Ovid, NY
- 2014 XTX Viper MCX 270 HP
All you need is some exhaust pipe and weld her
together
tapex_07
- Feb 15, 2009
Mine is out of the hood, my buddys was under hood.. The fresh clean air helps!
