WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Hey fellow Riders...
i am about 190 with gear, and i can`t explain how good the float is on large bumps (washouts, ruts, holes whatever it is the float can take it )
the float is awesome on the bigger stuff feels like your sitting on a air balloon when hitting the big bumps..
did about 80k on a hard packed semi rough trail with washouts no problems.. going to be a killer shock once guys start tuning these things..
i was hitting some big washouts.. the faster i would hit them the better the float felt..
i have the float set at 150 right now (under spec for a 190lbs rider)
it`s to stiff on the stutters..
i adjusted my transfer to min and going to be lowering the psi a little.. to see any diff..
they should of put a rebound knob on there..somehow.. i guess mega float 2.. i think the rebound needs work... a little to fast for me... or the comp, is to hard
i have the front strap at its longest position.. would lifting the strap up help on the stutters..
i haven`t really had a chance to go through a long stretch of stutters (Good Thing ) to see what happens..
one thing is for sure i feel the front suspension more now then with the ohlins..
any thoughts..
any thoughts..
