viperwings
- Oct 28, 2007
- Michigan
- Attack GT & Nytro XTX
- SE Michigan
Just took my new 07 Attak GT out last weekend in Kalkaska and it was great. However I lost one of the stickers and need to get it replaced. I wanted to know if I clean the Black plastic with some cleaner and try to get most of the oils off of the surface will the stickers stick? I seen a guy with a riveted on plastic plate that seemed to work good. Does anyone know where I could get two of these. He said he got them at the Novi snow show but did not remember the vendor. ANY HELP?
yamadooski
Stickers
I used denatured alcohol to clean the surface then put the sticker on the removable side panels. I used a heat gun on low to warm the adhesive and smooted it out then rode it 300 miles last weekend with no problems.
RTXgary
I bought a plastic reg sticker plate at the Novi show Very easy to install. Check out the attached link. They even had a picture of the plate on an Apex. http://www.sledsolutions.com/store/pictures.php
Ported Hornet
Re: Stickers
Same here. 1500 miles no issues.
yamadooski said:I used denatured alcohol to clean the surface then put the sticker on the removable side panels. I used a heat gun on low to warm the adhesive and smooted it out then rode it 300 miles last weekend with no problems.
sobfrogg
I use a good window cleaner. then make sure the surface is warm to the touch. If needed a heat gun or even a good lighter if you are in need. Then stick the sticker. Always works..
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
I did as above, cleaning the area very well, then hairdryer on high to heat the panel, apply sticker and more heat to seal it. Been on for 1,600 miles
