Mid mount turbo
I've never seen that bike, my SRX was blue and yellow, the dune buggy I built was also yellow. I decided after I painted it yellow to use the R1 50th aniversasry colour scheme on the hood.
Your sled looks great, please post more pics when you're done with it.
They've been dyno tested on the RX1 and field tested on the Apex and work great. The only issue that has come up is that the super chargers make a lot more noise but it can be adjusted out.
I made my own 2 stage boost controller and have run the power thru the knock sensor so when there is a series of knock events it will back my boost down.
I have been running Blair's box with success on the Apex with the supercharger it was picking up rich knock for me once I got my AFR tuned out it seems to be great. I get the odd knock occurance in the mid which I think is from the accellerator pump setting on the mpi box giving it a squeeze of fuel and causing a rich knock on the bar you can make it knock if your to lean or rich but at 12.3:1 its mint.
Sounds like what everybody needs! :Rockon:
Brett isn't that alittle personal asking about Blair's nuts, lol. :moon:
ya for a little guy he has alot of problems with his nuts.
