sinjin
I have been thinking of switching to Mobile 1 oil in my Attak. After reading many threads from a search on this site I am even more confused. What weight oil should I use 0W-30 or 0W-40 or ??? Any reason to not switch to Mobile 1. Often I ride where tempretures can be as cold as -40 and the cold starting abilities appeal to me.
Tork
I run 5-30 but 0 30-40 would be better in minus 40 temps
I'm running 0-30 this year, but I think I'll be changing to 5-30 next year simply because the zero weight is difficult to find. 5W-30 can be purchased at Wal-Mart for about $22 for 5 quarts.
SharkAttak
i've been running 5w-30, there is really only a slight difference between 0w,5w and 10w, there was a post about it last year
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
I switched my 03 LE to Mobil 1 0w-40 this season.....maybe it's my imagination, but it seemed to help a little with the oil burning issue, as in longer between adding......$6.47 a qt at Walmart......still almost $2 a qt cheaper than Yamalube semi-synthetic.
Tork
jwifferdill said:I'm running 0-30 this year, but I think I'll be changing to 5-30 next year simply because the zero weight is difficult to find. 5W-30 can be purchased at Wal-Mart for about $22 for 5 quarts.
Exactly, those 5 qt jugs make it easier to handle used oil for recycling too!
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
I am using amsoil 0w30
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
buddah2 said:I switched my 03 LE to Mobil 1 0w-40 this season.....maybe it's my imagination, but it seemed to help a little with the oil burning issue, as in longer between adding......$6.47 a qt at Walmart......still almost $2 a qt cheaper than Yamalube semi-synthetic.
Not your imagination, my subaru drinks mobile 1 5 or 0w30 but 0w40 she doesn't use a drop. I'm going to run 0w40 in my RX next year as I am burning a little as well and see if it helps compared to the M1 0w30 this year.
vx700xtc
3000 miles of 0w40 in 07 attak, no all seems well.
rxwhopper
when i put the 0-40 amsoil in my rx-1 it totally quit using oil
SharkAttak
how much is amsoil a quart for 0w-30?
I know in Ontario I buy Amsoil for $10 a litre, not bad for a full syn. 0w40 , don't burn a drop......
favarcat
I've been using Mobil 0-40 also for the last 11,000 miles. Easy to get at our local AutoZone.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
0w40 amsoil @ Napa
SharkAttak
kyzer said:I know in Ontario I buy Amsoil for $10 a litre, not bad for a full syn. 0w40 , don't burn a drop......
thanks
