Mono shock clip?
hereismylife
pa
09 apex gt
Who can tell me where the clip is on the mono shock?
What clip are you referring too?
I think you are referring to the limiter strap.
So I guess I don't have that clip. Don't see anything like that. Just the ring adjusters at bottom and the spin knob at the top
Here what it looks like
The clip is under the adjuster. You need a spring compressor to change the clip location
We have the spring off. Collar is off. Don't see anything. When you say adjuster are you talking at the spin knob?
The location of the spring seat is fixed on the one end (rebound adjuster end). The other end is the adjustable nut that compresses the spring and gives the pre-load. You can only adjust the pre-load so much before you start running into coil bind. Then you could damage the shock.
The location of the spring seat is fixed on the one end. The other end is the adjustable nut that compresses the spring and gives the preload. You can only adjust the preload so much before you start running into coil bind. Then you could damage the shock.
I just want to know where the clip is? We have the seat and spring off
