kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Hey guys, need some more help. In my previous post I was saying I lost power to the fuel pump. When this happened I was going down the trail probably 40 mph and the sled just instantly died. Well I found that 10 amp fuse on the starter relay and replaced it with a 20 amp and thought I had my problem fixed as I got power to pump.
I start it up and a code 20 is flashing and it will not idle, its goes lean off the charts and dies. if I rev the gas I can get it to rev up and hold 2000 rpm for just a second or two then it starts going lean and dies again. If i rev it I also hear a back fire.
Code 20 is atpmoshereic pressure right? I'm lost here need some help. Sled is MPI stage 1 with GEMS and I do have the sled start installed.
kinger
- Jan 17, 2005
- Clear Lake, IA
Sorry boys I pulled teh trigger to early I did some searching and found the post I bumped by iahacker and unplugged my GEMS, reset the 15 or so codes in there! Yowzas she runs out of fuel it triggers a lot of codes LOL
Started up perfect, plugged GEMS back in started up perfect increased idle to 1550 vs teh 1500 I had it and she purs like a kitten and throttle response is insant.
thanks again TY!!!!
thanks again TY!!!!
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
You welcome buddy, glad you found it that quick.
JLR
- Dec 6, 2006
- Winnipeg, Mb
- Currently, 2017 Arctic cat thundercat 2018 sidewinder xtx se 137 precision stage 4, 2025 Yamaha Srx bone stock
code 20
do you have a post to the link you referred to.
kinger
- Jan 17, 2005
- Clear Lake, IA
