More Throttle Position Sensor Questions
chasedan
Grand Rapids, Minnesota
Hello All,
I have a 98 Mountain Max 600. I replaced a defective Thottle Position Sensor. My question is the calibration on the sensor.
I have a service manual for this sled and am following the procedure for calibration. I believe there is an error in the manual.
The formula printed in the manual is Vb=Va x (.121 x .129).
In my case the 'a' voltage is 4.77. Calculating 'b' voltage gives about 74 millivolts (0.074 volts).
When the engine is idling at this TPS setting the diagnostics light flashes two long flashes and one short flash, indicating a open circuited TPS.
If I run the engine at about 4000 rpm the flashes stop.
If I re-adjust the sensor to about .70 volts on Vb at idle the flashes stop.
Are there any ideas on the proper TPS setting for this machine? Has there been a revision or correction issued on the manual for this machine?
Just flat looking at this, the parentesis would have no reason being with a multiply sign. Therefore, i suspect a miss typo from a plus... no.. perhaps a miss read. Thus, Vb becomes 1.19
Take it as a wild guess :)
The 07 Nytro manual reads: Specified voltage B = Voltage A × (0.136). I believe the (.121 x .129) in your manual states the acceptable voltage range for VB so,
VB (min) = 4.77 x .121 = .577 Volts
VB(max) = 4.77 x .129 = .615 Volts
VB should be set between .577 and .615 volts
