MPI 180\90 sea level boost gauge ?
upei93
Dalhousie, NB
Canada
2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
Can somebody post a picture of where you t'd in your boost gauge hose on the MPI sea level kit...hard to get a straight answer and I need pictures for my brain to get it lol. I've read on here one of blue lines but instructions say not to do this...
From MPI...
DO NOT CONNECT ANY GAUGES TO THE BLUE BOOST CONTROL HOSES
DO NOT CONNECT ANY TYPE OF ACCESSORY TO THE BLUE HOSES.
Thanks!!
Boost gauge is an autometer mechanical oil filled.
I think the hose you don't want to disturb is the one going to the GEMS. I cant post a pic but mine is connected into the cluster of small lines that go to the throttle bodies and blow off valve.
Thanks! This might be easier if I post pics and you guys guide me...I just want to be sure.
This one?
This one? Comes off of turbo (I think) front of engine.
This one goes to waste gate actuator (blow off valve?) The guy at my dealer told me on his Cat 9000 he t'd in after the turbo.
I just bought the sled with the turbo installed...my first turbo...steep learning curve! Thanks again for the help!
yes this is where I have mine tee'd in I am on a super charger I don't think that matters.
OK...I just sent the pic to MPI to be sure thanks again!
Got my answer from MPI
perfect I think that is the same line I was talking about those are the nipples by the throttle bodies right?
Think so...Im not at home to check it out...thanks again for the help!
OK so I have my boost guage figured out...what are you Viper guys doing (wit OSP gauge mount) when it comes to running the wires to power? Do you have some sort of plug in to allow the hood to come off? Where/how did you tie into power? Just looking for ideas. thanks!!
