iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
- 13 xtx nytro stage 1 turbo
I just upgraded my nytro to a 13 xtx 180hp turbo and the dealer replaced the battery and I read the Gem box will lose it's programming? I have searched the web and you tube for an easy way to program this thing? The mpi instructions are not making any sense to me how to program this box. Anybody got any links or simple way to get this done?
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
Why would it loose it programming? Once set, your good unless you want to fine tune it. This should be kind of close and maybe help you understand the box.
http://viper.mountainperformance.com/Viper-GEMS-Controller_ep_48.html
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
Thanks so much for the information!!
I have stage 1 set up with only a boost gauge that I can't read under load but I think I am running no more than 6psi of boost and mountain performance recommends a air/fuel mixture information. Anybody have a picture of there setup gauge mounts etc. I have tried and searched with not much results. All help is very much help!!
olivia317
- Jan 20, 2013
- Olivia, MN
- 2012 FX Nytro XTX SC
Without an Air/Fuel Gauge you are asking for trouble. Adjusting the Gem is impossible without knowing your air/fuel ratio. Dave at Hurricane Performance has a really nice bracket to mount both A/F and Boost gauge next to gauge pod. www.hurricaneperformance.ca
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
olivia317
- Jan 20, 2013
- Olivia, MN
Start with the Low Level settings(bottom settings). These are very close to my settings, I am at 1000ft. The A/F gauge is a MUST! You are playing with fire without it. Mounting the gauges is the easy part, welding in the bung for the O2 sensor is more time consuming. Stock pipe is stainless steel. Usually needs to be TIG welded. Put in the O2 sensor.View attachment 135702 So would this be an ok baseline to run and test with a air fuel gauge installed I used the updated below 3000 feet and I am below that altitude.
There is never time to do it right, but there is always time to do it over.
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
So where are you guys putting the O2 sensor at? Between The turbo in the motor on the stock pipe? Thanks Brian
olivia317
- Jan 20, 2013
- Olivia, MN
It needs to be between the collector(3 into 1) and the muffler, before or after the turbo shouldn't matter. The sensor should be mounted in the top half of the pipe, usually 1-2 o'clock or 10-11 o'clock position. That way condensation cannot pool in the sensor. Also helps protect it from ice and snow.
iwillwait4u
- Aug 30, 2011
- Churdan, Iowa
Thanks a ton for your help!!!!
olivia317
- Jan 20, 2013
- Olivia, MN
You're welcome. Hang on to that thing!
