juwalantz
I have a MPI supercharger kit. The taper lock bushing inside the lower pulley broke in half. The pulley was damadged in the process. I need to purchase a new pulley and taper lock bushing and set screws. Does anyone know where I can find them.
Call MPI, they should still have them in stock.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Year old thread, did you find a source? My taper lock on the jackshaft of my apex kit did the exact same thing. MPI number does not work. I'm thinking I can get one from like a Grainger or something? mine is marked 3/4" and 1108
I've bought them at grainger but the pulleys are steel.
Ryanshimon
- Feb 6, 2020
- Minnesota
- 2010 Nytro XTX
Heres what I ordered.
https://www.ebay.com/itm/1108-X-3-4...944673?hash=item4b6e971e61:g:RmEAAOSwlqJdcwct
Grainger did not have anything in stock so I couldn't verify if it is correct. Seems pretty standard from what I have found. I'm currently waiting on the supercharger belt to come in to see if that was right.
So far I have received little to no support from any vendors and unless you have a part number for what you are looking for you are flying solo.
I had to order them through grainger also but they came in pretty quick. I will look to see where I got my last belts, can't remember where right now but I do remember they were much cheaper than mpi
Faulkner
- Jan 12, 2020
- Labrador city newfoundland
- 2003 turbo rx-1
2006 MPI supercharged apex
2009 800 assault
2005 900 switchback
Ordered my taperlocks from amazon
Martin 1108 7/8 Taper Bushing, Sintered Steel, Inch, 0.87" Bore, 1.511" OD, 0.875" Length
Also I got belts from NAPA
