FLYBYU
Anyone have the shaft break on one? 300 miles on this one and the impeller seized and sent shavings into the engine. Waiting for the head to be taken off at GNS to what damage was done. I know it didn't run without oil as I did to exact directions. Started for a minute and made sure oil was flowing. Set the vent where it would never see water or snow to suck in it and freeze. Didn't over spin it as it only 28 28 pulleys on it. Were sending it back to MPI on Monday and see if they'll warranty this.
FLYBYU
NeverEnuf
Just happened to me on Monday, I didn't have shavings that big. Mine just left a really fine dust. I had 656 miles on mine. How cold was it when it happened? Did you check your oil as soon as it happened?
NeverEnuf
I went in with a borescope and I didn't see any damage, still think I'll do a leakdown.
FLYBYU
Yes it was 0 degrees. The engine actually shut down because the shavings got into the Valves and we lost compression. Oil was fine.
Neverenuf, Did you engine shut down?
NeverEnuf
My motor never shut down. I heard a loud whining and shut it down.
It was -15 when mine went down. I checked the oil as soon as it happened and my oil looked froze. It stuck to the dipstick when I pulled it out. This was the second ride on this oil. When I let it sit in the shop overnight and checked the oil in the morning it looked like I just poured it in. When I changed the oil and filter it had proper flow, I think mine was oil related not the blower itself.
FLYBYU
Did you not let it warm up? I put the vent line in a dry spot lower than tank as instructed to do. Sled was running for atleast 15 prior to riding. Went about 10 miles before it let go.
NeverEnuf
Yup, my vent line was routed under the ecu lower than the tank in as dry of a spot as there is. Mine went down about 45 miles into the ride.
I first thought I blew all the fluid out. Since new mine has always blown a little fluid out the vent hose for some reason. But when I talked to Matt and others that wasn't out of the ordinary. Some guys run the vent to a bottle to catch the overflow. I was told to keep an eye on it and it should stop blowing out the vent but still have sufficient oil for the blower. When mine went down the oil level was still full.
FLYBYU
Sent you a pm
FLYBYU
The oil inlet doesn't even line up.
Loneida23
- Jan 17, 2015
- Yamaha Nytro MPI Supercharged stage 2
I have not had any problems with my charger but the last ride my sled started running rough. I pulled it in the shop the next day and found a plug it's about 3/4" but I cannot find where the heck it came from and my sled is running like po-po now and I am starting to get aggravated. Any suggestions or maybe someone who has installed this system and knows what I am talking about and where the plug is supposed to be
FLYBYU
What does it look like?
