phzmtnlite
anybody hook the bars on their Mtn Lite. If so, what did you go with?
Idaho Nytro
I found some bars off a 06 vector mtn se.
jp@weknowsnow
45 degree bar ends from parts unlimited snow catalog
remove the rubber around the end of the grip, start in the small hole and work your way out until you hit the inside of the handle bar. once you do that you need to drill out 1 rivet on each side of the bars.. clean it up and pop the bar ends in. here is a pic:
Phazed-Coug
I think we should raise issue with yammi on this one..
the 2007 brochure listed hooked bars, and they came without.
the 2008 MTX is coming with hooked bars(so far)
I'd love hooked bars, but I don't want to "add on" I want a full bar.
