SRXracer
Does anyone know if a apex mtn handlebar riser will fit on a GT. I sat on a RTX today at a gas station that had a home made 2" riser, and it fit me perfect at 6'-2" tall. I heard the mtn riser was a couple inches taller, but not sure if it is a direct bolt in?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
It will bolt directly on, but I believe you'll need longer throttle and parking brake cables as well as the longer brake line. You'd also need the 4 bolts to hold it on as well.
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
just have to install the longer throttle cable, use the montain cable
The stock will work as well, but if it gets hung up it pulls the cable out of the sleeve.
Been there done that.
SRXracer
sounds good guys, i think i am gonna order it and give it a try. Allen, just got done with a 800 mile ride in the UP, i've got some feedback for ya, i'll give ya a call or bump you on messenger.
eric
eric
