My RX-1 Works
I said in the posts that my gear ratio was 2.58:1 , that is correct for 8tooth drivers, because I use 7 tooth drivers the real number is 2.87:1. I also said that the top speed was 75MPH at 1:1 , this is not correct . Top speed is 65MPH at 1:1 , with a theoretical top speed of 78MPH at 0.80 overdriven. Sorry, I strive to be accurate.
In the Turbo clutching post the gearing numbers being thrown around were 20/39 with 9 tooth drivers. This is a 1.95:1 ratio.
Turbo on low boost at 10,300RPM- 120 foot pounds of torque
My stocker at 10,300RPM- 83 foot pounds of torque
Clutch ratio in low gear- 3.8:1
Torque at drive shaft Engine torquexclutch ratiox Gear ratio
Turbo- 120 x 3.8 x 1.95= 889.2 foot pounds of torque
My stocker 83 x 3.8 x 2.87=905.2 foot pounds of torque
Hey this is wierding me out, the stocker is making more power of the line, oh well, maybe it just needs a little more boost!!
