ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
It is a very linear adjustment though, making the adjustment across the whole RPM spectrum. So if you increase the ratio by 1, it will do so from engine start to max RPM. .
That's good to know. I was under impression it was only for low end/start up. I've been a little leary to adjust this setting but think I'll try it now knowing it's for the entire RPM range. Thanks Moose
I think you should try it Ruggy.
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Maybe next year. The sleds running great and with my new helix clutching is perfect. I can't imagine it getting better, it's running that good!That's good to know. I was under impression it was only for low end/start up. I've been a little leary to adjust this setting but think I'll try it now knowing it's for the entire RPM range. Thanks Moose
Ruggybuggy
- Sep 1, 2013
Forgot to mention, if your going to mess with the air/fuel ratio pull the plugs out first and read them. If they look good don't mess with it. Run it lean and you could cause some damage.
ATV PRO #11
- Jan 22, 2011
Don't mess with what ain't broke!! I hear ya there.
If i mess with mine it'll be to fatten it up a point or two. Piping usually causes a lean condition.
I'm piped, i know. Working on fixing that currently
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
Did you end up going 45/41, or straight 41*, I can't remember what you were looking at
Ruggybuggy
- Sep 1, 2013
I did the 41 and it works very well.Did you end up going 45/41, or straight 41*, I can't remember what you were looking at
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
Now hop back on to a box-stock Phazer and it will feel like a dog! Seriously! LOL
- 6K
