Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
06 apex gt w/ reverse. Blew a chain case chain. Anyone know where i can get one.....IN CANADA?
Not to doubt u, but just be sure it wasn't the drive axle that snapped.06 apex gt w/ reverse. Blew a chain case chain. Anyone know where i can get one.....IN CANADA?
yamhaattakman
- Jan 31, 2016
- Renfrew Ontario
- 2007 yamaha attak
Royal distributing. I naught a few ther with good luck. Ull hafta make shure u get the right number of links
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Yup. drive axle snapped. you called it. I take it this is a common problem? Can i still gert a drive shaft from yamaha? Anyone got a good used one theyd like to sell?Not to doubt u, but just be sure it wasn't the drive axle that snapped.
YukonMP
- Dec 25, 2014
- Yukon Territory
Latest post in classifieds is a guy parting out a 2006 Apex ... how do you spell BINGO!
- Jun 28, 2004
- Clinton, Wi.
8000-10,000 miles seems to be the range for the 06-10 Apex drive shafts. I had a long cold evening in January of 2012 because of one of these lol!
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
I'd look into the heavy duty one. I found out after there was a hd one available aftermarket. I already had a new stock one in.
Hi Darren06 apex gt w/ reverse. Blew a chain case chain. Anyone know where i can get one.....IN CANADA?
I have a good drive axle with Extroverts installed, close to home, PM me if interested
Bob
I would go new if it was mine. They are not terribly expensive, I think $230 last time I bought one.Latest post in classifieds is a guy parting out a 2006 Apex ... how do you spell BINGO!
Unless you know it has low miles.I would go new if it was mine. They are not terribly expensive, I think $230 last time I bought one.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Thanx guys i will choose wisely
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Bob i cant run extrovert drives because some of my windows in the track are not open. Do u have just a stock set instead?Hi Darren
Bob
I have a few drive shafts...will have to check on the drivers I have.
You could always open the third windows on the track with a hole saw and Dremel if needed...extroverts would be a preferable way to go as you can run the track a little looser and eliminate the driveshaft breakage issue.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Whole saw and a die grinder huh? Ok.
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
I opened up all the windows on my every 3rd track. I used a little reciprocating saw that I purchased for $40 at Menards. It makes the job much simpler. After you cut out a few and get the hang of it, the rest go much faster. I took it a step further by adding clips where the windows were cut, making it a fully clipped track.
- 9K
