08nytrofx
 - Nov 25, 2008
i'm thinking about putting new bars and a riser on my nytro i kinda find these a bit small thinking of put some that are 32inches wide or something like that has anyone else done this
any opinions?
and would i have to buy the extended throttle cable if i put a 3.5 inch riser(pivitol) and like a bar with like 2 inch rise in it??
thanks
			any opinions?
thanks
micheal_654
 - May 10, 2008
 - Carbonear , Newfoundland , Canada
I put the rox 3.5 on mine and i didnt need an extension for the throttle , but i did re-route cables with the stock handlebars on the standard nytro , so thats fairly close to a 2 inch rise. But it's almost to close to call whether or not you need a throttle extension
			08nytrofx
 - Nov 25, 2008
did you reuse the stock bars cause thats the riser i'm getting but want different bars do all bars work or do you need a certian size and i cant see my father going for the re routing partmicheal_654 said:I put the rox 3.5 on mine and i didnt need an extension for the throttle , but i did re-route cables with the stock handlebars on the standard nytro , so thats fairly close to a 2 inch rise. But it's almost to close to call whether or not you need a throttle extension
lucky_7
There are a lot of riser and bar options on http://www.rsiracing.com/
			micheal_654
 - May 10, 2008
08nytrofx said:did you reuse the stock bars cause thats the riser i'm getting but want different bars do all bars work or do you need a certian size and i cant see my father going for the re routing partmicheal_654 said:I put the rox 3.5 on mine and i didnt need an extension for the throttle , but i did re-route cables with the stock handlebars on the standard nytro , so thats fairly close to a 2 inch rise. But it's almost to close to call whether or not you need a throttle extension
I re-used the stock bars and most all handlebars are 7/8" except for "fat-bars" , if you get the rox risers you will need standard 7/8" bars.
08nytrofx
 - Nov 25, 2008
what about a riser that goes from 7/8 mount to a 1 1/8 mount cause i'm thinking about putting dirtbike bars on it
		Muffin
 - Oct 5, 2006
 - Marathon, WI
 - 2014 SR Viper RTX SE
If your looking for risers we have em'.  We are a TY sponsor and have sold a ton of them to TY members. They are even on the TY build sled.  Talk to Mr. Sled.  Check out our website and if you have any questions please let us know.
www.muffinworksltd.com
email: sales@muffinworksltd.com
Old Dog
Dirtbike bars will most likely be Aluminum. I put a set on my mod Viper and they really dissipate the heat away from the warmers. FYI
			08nytrofx
 - Nov 25, 2008
well you can chosse steal, aluminium anything actually
			loudelectronics
 - Dec 1, 2007
 - Souris, Manitoba
 - presdwr.spaces.live.com
I am thinking about putting protaper ATV contour hi bars.  I have them on my grizz. The ergos are exceptional.  Then use a Rox riser to top it off.  Not sure if I need bar ends though.  have not figured out there purpose yet.  Apparently these can be bought according to the links above.
