03rx1mn
- Jan 24, 2008
- Spring Valley, WI
- 2015 SR Viper RTX LE
2007 Apex RTX, Yamaheaters
2016 RS vector
Good day folks. I have a 2016 RS Vector that I just bought. Only 850 miles on it. Engine light is on steady, no flashing. I do not see any codes, and the sled is not near me at the present. I am hoping that someone can help me. The light is not flashing, it is on steady. The yellow light is on, and an engine is lit up in the display.
Has plenty of oil, I reset the oil change reminder to zero, light still stays on. I am afraid to ride it, but I have never had a sled with this low of miles. I am not sure if there is a reset or something else I have to do .
Thank you in advance., I did try to search for this, but I have had no luck.
Fuel level?Good day folks. I have a 2016 RS Vector that I just bought. Only 850 miles on it. Engine light is on steady, no flashing. I do not see any codes, and the sled is not near me at the present. I am hoping that someone can help me. The light is not flashing, it is on steady. The yellow light is on, and an engine is lit up in the display.
RobX-1
- Coldwater, OH
Just saw the sleds in your signature so disregard.
03rx1mn
- Jan 24, 2008
- Spring Valley, WI
2016 RS vector
Fuel is more than half tank. Then I filled up, same thingFuel level?
RobX-1
- Coldwater, OH
With that low of miles, I doubt you had the air box off but one time when I removed mime, I forgot to connect the plug back into the air temperature sensor on the clutch side of the air box. Although it displays the engine icon on the gauge, I believe it flashes it but might be something to check.
03rx1mn
- Jan 24, 2008
- Spring Valley, WI
2016 RS vector
I did have it off, I had to replace the battery. It had been sitting for 3 years. Thank you. I will check that. It is not flashing though. it is on solid.With that low of miles, I doubt you had the air box off but one time when I removed mime, I forgot to connect the plug back into the air temperature sensor on the clutch side of the air box. Although it displays the engine icon on the gauge, I believe it flashes it but might be something to check.
03rx1mn
- Jan 24, 2008
- Spring Valley, WI
2016 RS vector
Any other thoughts would be appreciated. Thank you
No other numbers showing on meter?
03rx1mn
- Jan 24, 2008
- Spring Valley, WI
2016 RS vector
Nothing. Wish I had a picture. Just engine symbol and yellow light lit all the timeNo other numbers showing on meter?
Are you sure there isn't a 2-digit number displayed?
03rx1mn
- Jan 24, 2008
- Spring Valley, WI
2016 RS vector
Was 100% sure, now I am 95% sure. Seems like I should have seen something, but I looked pretty hard.Are you sure there isn't a 2-digit number displayed?
RobX-1
- Coldwater, OH
Is the sled still not near you?
Considering you recently replaced the battery, you will probably need to retrace your steps to ensure everything was properly reconnected.
03rx1mn
- Jan 24, 2008
- Spring Valley, WI
2016 RS vector
The sled is not near me at the moment. This light was on before I changed the battery. The battery did not have enough juice to turn over but took charge enough to light up the gauges.Is the sled still not near you?
