Roger
- Feb 10, 2007
- Osgoode Ontario Canada
- 2012 RS Venture GT (power steering doesn't work when real cold)
2006 Indy 500
Hi All
Where do I find what the warning light flash code means. My 2007 RS Venture has started flashing twice, with the engine symbol displayed. I have not had any luck with this sled since an oil change in Arnprior. Help!!
NormT
lite
A flashing lite means check problem asap. Oil level o.k. ? Senser for oil connected ? The lite should have a symble in it when flashing,compair the symble to your owners book. normt
Look at the trip meter as it flashes.... this should display a code.
Code list is available on this site; use the search function... it works.
snopup
Roger said:Hi All
Maybe call your dealer?
Roger
- Feb 10, 2007
2006 Indy 500
I guess I'll have to bring it to the dealer. It won't even start anymore. This snowmobile has been the biggest P.O.C. I have ever owned. Ever since Arnprior Sportland changed the oil, it has been a P.O.C. It has to go.
This is why I change my own oil. You never know who they let work on your machine or if the mechanic made a mistake and forgot to add oil, started it, realized he made the mistake put oil in it and said it was good to go. Doesn't sound like the sled is the problem, sounds like its the dealership that did the work. Just a suggestion, I would hope that this wouldn't be the case but I'm sure that stuff like this happens on occasion. Sorry to hear about your troubles.
snopup
Is it possible they overfilled the oil? that would cause all kinds of problems....Very important to check/add oil only when the motor is hot.Roger said:Hi All
Roger
- Feb 10, 2007
2006 Indy 500
snopup said:Is it possible they overfilled the oil? that would cause all kinds of problems....Very important to check/add oil only when the motor is hot.Roger said:Hi All
Oil seems o.k. There is about 3000miles since the oil change, but it never ran right since Arnprior Sportland changed the oil.
Roger
- Feb 10, 2007
2006 Indy 500
I had already responded that I thought the oil was o.k., but I realized afterwards that it was a touch high. I have posted a new thread asking what could happen if there is to much oil in it. Not impressed with the dealer in Arnprior.
guyzoun
- Feb 3, 2006
Roger said:snopup said:Is it possible they overfilled the oil? that would cause all kinds of problems....Very important to check/add oil only when the motor is hot.Roger said:Hi All
check the oil level with the dipstick not screwed in, and engine warm. Not enough oil or too much oil will get sucked in your airbox.
You can also go in the "Need a Fix" forum.
good luck
Roger
- Feb 10, 2007
2006 Indy 500
Thanks for the help everyone.
Where should the oil level be when cold?
snopup
RIYAMAHA said:Where should the oil level be when cold?
Don;t check it cold!!! Has to be hot!!!!!
