sunsation1
Have 06 apex code 12 is showing on dash replaced cam sensor still showing same code tried starting fluid still no start any way to check stator I went through profaning on cluster to try an clear cant get it to clear
marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
If you're getting Code 12 that's pretty much a done deal, time to replace the stator. With an 06 apex, I'd say you're right in line with most people. I replaced mine last year. It'll never start with starting fluid. I believe Code 12 shuts down ignition and fuel delivery.
jackback
Stator for sure, just changed mine, had been acting up for a few weeks, not starting right away etc. It will be the crank sensor most likely but you have to replace the whole unit. Lots of used ones around for $100 bucks. Only took two hours to change, easy job!
sunsation1
It was the stator changed all is good now thanks for the help
hotrod
- Nov 16, 2008
- Maine
- 2007 Apex GT
My Yamaha manual says that cold 12 is a crankshaft positioning sensor. Why are you people saying it's the stater
Well we are saying it is the stator because the cranksaft sensor and stator are together. If you need to purchase through your dealer they are wired together and can not get separetly. Their are aftermarket sensors available if you are comfortable cutting and splicing the wires.
