Need help distinguishing what Nytro I have
WINDER1987
Upstate NY
Hello so I bought a 13 nytro xtx last year used. It did not have the 1.75 track that most come with it had a 1.25 track but with no tunnel. Protectors if you wanted to stud it. If I understand correctly the 1.75 bc model did not have the tunnel protectors because it could not be studded.
It makes me wonder if the dealer took the bc track off and put it on another sled or sold it or the previous owner did which I cannot get in touch with.
I'm just curious which model mine was originally and if the only difference between the two Is the tracks? Would they each have different gearing too? If so what gearing?
I tried searching my model number and Vin # and didn't see much
Call any Yamaha dealer and give them the VIN and they will tell you what you are suppose to have with that VIN.
The 1.25 version has standard drivers and front cooler protectors
Sent from my XT1254 using Tapatalk
Very possible that it is a regular XTX, but the previous owner removed the tunnel protectors to try and decrease the icing issue.
The standard xtx didn't have extrovert drivers didn't have a extra heat exchanger and came with the ripsaw track. That's how I understood it to be. Could be wrong could be right can't say 100% certain but that's what I was led to believe.
Regular didn't come with tunnel protectors in 13 only cooler protectors
Gearing is different, 21 vs 20 tooth top sprocket 1.75 vs 1.25.
Also like mentioned the 1.75 will have the aux cooler in the right side of the tunnel.
Yes if it has the aux cooler on the rightside of the tunnel and extrovert drivers on the outside (left+right) of the driveshaft it would likely have originally came with the 1 3/4" BC track.
Ok thanks for clearing it up guys I'm pretty certain now mine was just the 1.25 version stock
