NEED HELP PLEASE!!! Removal of Idler Wheel Bearing
Mrsteak21
First off, thanks in advance for responding. I used the search function, but couldn’t find what I was looking for.
Long story short, I broke a control road on the back suspension and need to get the idler wheel assembly and bearing off to replace it. I have removed the plastic idler wheel, but the dang bearing will not come. Ive tried heating it with a blowtorch, banging on it with a hammer/block of wood, etc. Either the bearing is fused/rusted on the shaft or I am completely missing something.
Ive talked to a couple dealerships and they instructed me to do the same things as listed above – they did recommend an air hammer but I do not have one. Any thoughts or tricks to getting the bearing off the shaft (without ruining the shaft)?
I have pictures on a slideshow on youtube - http://youtu.be/6a9gjqyXCaI
Thanks in advance!!!
Soak in penetrating oil for a day (several applications) and try again with heat, hammer, etc. Cool the shaft with wet rags after heating the bearing.
Last resort is die grinder with cut-off wheel. That should get through it fairly quickly.
This sounds like a common issue though, so i am guessing I am on the right path.
there is a 14 mm bolt on the end, then a sleeve - both of those are removed. i took the snap ring off of the idler wheel and it is now removed. now only the bearing remains and i do not see anything holding it onto the shaft.
the shaft, or wheel stand off should also be attached with that 14mm bolt. the stand off should come off allowing you to put the bearing in a vice, or work on the bench.
Not sure if you looked at the pictures in the youtube link i provided, but there are a handful more of bolts you would need to remove to get the shaft out. it is attached to the mono shock among other things.
whoops sorry, in that case i'd soak it with pb blaster or a good quality penetrating lubicant. try to get to the back of it with a chisel and 5 pound hammer if possible, unless you want to save this bearing, then i wouldnt do that. if that does not work cut it off, cut the outer race in 2 halves, then on an angle like this / cut the iner race almost all the way through, then hit the cut with a sharp chisel. bearings are hardened steel, so it should crack, once it cracks it will come off.
You're probably just going to keep fighting it until you pull the skid, tear it down and use a press to remove the bearing. I recall one of my previous no-action skids taking a heck of alot of psi to get that wheel bearing off.
Pull the skid and press it off...BUTT...
if you have a small steering wheel or bearing puller....like this... it will come right off
The worst you would have to load it...heat it a bit and then remove it
:sled1:
That's good ol' fashion steel mated to aluminum that sits for 10 months out of the year.
If you use a puller, thread a bolt inoto the shaft so you don't damage it. Also, use steel wool or a Scotch Brite pad to scour the shaft before you pull.
However you get the bearing off, you may discover the bearing has spun and ruined the shaft.
Thanks to all for your replies. I am going to pickup a bearing puller and see if that does the trick. I will lube it up and heat it again prior to trying. Hoping that the shaft isnt (or will be) ruined.
On a side note, would riding it with only 1 control rod further damage the suspension? I have the standard suspension and 121" track. The control rod is on backorder right now and im itching to go out.
What he said....
