glas0233
- Sep 30, 2014
- Minnesota
- 2003 yamaha rx1, Past sleds: 1990 Arctic Cat Prowler, 1996 Arctic cat 440z, 2004 Ski Doo Renegade 800, 2005 Arctic Cat M7
I have an 2003 rx-1. I just changed the exhaust donuts and got my carbs cleaned and synchronized. At idle it has a continuous backfire. Any idea what could be causing this? The exhaust doesn't seem to be leaking as I have plugged the tail pipes and it wants to stall. could the carbs still be out of sync? dirty carbs? I have attached a video so you can here the exhaust. Thanks for the help!
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
No video attached. Could be number of things, coil? After dark start it with hood open see if coils are arcing.I have an 2003 rx-1. I just changed the exhaust donuts and got my carbs cleaned and synchronized. At idle it has a continuous backfire. Any idea what could be causing this? The exhaust doesn't seem to be leaking as I have plugged the tail pipes and it wants to stall. could the carbs still be out of sync? dirty carbs? I have attached a video so you can here the exhaust. Thanks for the help!
AftonJay
- Oct 23, 2012
- Northern Michigan
- 2005 Warrior, 2009 Nytro XTX and Arctic cat puma for the kids
- Afton Mi
That was going to be my next suggestion that maybe a coil is bad. Make sure you are getting spark to all 4 cyl and like BigDog said see if you notice any arcing with it running in a dark garage.
glas0233
- Sep 30, 2014
- Minnesota
Sounds good thanks for getting back to me!
smokingcrater
TORS is kicking in.. Your throttle cable is too tight.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Ya that would make it backfire.
