welterracer
I weight about 210 with clothing!
2006 Apex GT with 144 1.325 studs down the middle
I have a complete set of Heavy hitters from my Warrior i would like to reuse... I also have the smaller rollers, but ive heard the Apex already has those..
I also modded the helix for furthure shifting! (machining)
I need a setup for the weights to go in my APex..
I am not installing them till after December, when my buddy and i will get to race with his stock ZR900... (i want to see how they compare stock for stock)
Brian
Brian
Turk
Tech Advisor
Welter, you might have to add a little more weight but I bet it will be close to a straight bolt in. Install the kit, pm me with your rpm,s & it will be easy to dial in from there.
welterracer
The setup i currently have was setup for the ECP kit and slightly overreved! added weight twice to it as i think the engine gained alot more power the more miles i put on it..-
welterracer
If you feel you dont want to post a good setup on the net... Please feel free to PM me..
YammiMoose
- Mar 18, 2004
- In a place where it SNOWS every day
welterracer said:I weight about 210 with clothing!
Brian
What year is the ZR900?
Turk
Tech Advisor
Welter; I bet adding about 1.5 grams inner hole & 1 gram to the tip will get ya pretty close.
welterracer
It is a new 05 with 1 inch track
LazyBastard
Good setups are hard to come by for new sleds that haven't yet been tested in snow.
Turk
Tech Advisor
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I didn't use heavy hitters, but I'm showing about 9 grams difference in total weight from the Apex to the RX-1 using the same components.
welterracer
O.K. what did you delete??
Rideblueforever
- Aug 31, 2005
It surprises me by how many guys are messing with their clutching before they even ride the sled. Not only that but from the emails I have sent out to some of the top racers they recommend riding the sled first before I buy their clutch kit to see how the sled is working with the stock set up so I at very least know if their is an improvement from the stock set up to the clutch kit I buy if I think I need one after riding the sled. How is anyone of you going to know the difference of how the sled is reacting to the stock set up? Just a question
welterracer
Rideblueforever said:It surprises me by how many guys are messing with their clutching before they even ride the sled. Not only that but from the emails I have sent out to some of the top racers they recommend riding the sled first before I buy their clutch kit to see how the sled is working with the stock set up so I at very least know if their is an improvement from the stock set up to the clutch kit I buy if I think I need one after riding the sled. How is anyone of you going to know the difference of how the sled is reacting to the stock set up? Just a question
1ST.....I plan on riding my sled first! At the DEC TY RIDE! and racing my buddys 05 zr900 first to see how it compares!
2ND... there is always room left for improvement over stock clutching... I know SRXSPEC is getting 8 sled lengths over stock with his stage two kit! My warrior was very quick with clutching and a ECP kit.... I beat everyone i raced up to over 100mph..
Wouldnt you rather beat your buddys by 10 sleds instead of 1 or 2 lengths?
byoffcr
welterracer said:Rideblueforever said:It surprises me by how many guys are messing with their clutching before they even ride the sled. Not only that but from the emails I have sent out to some of the top racers they recommend riding the sled first before I buy their clutch kit to see how the sled is working with the stock set up so I at very least know if their is an improvement from the stock set up to the clutch kit I buy if I think I need one after riding the sled. How is anyone of you going to know the difference of how the sled is reacting to the stock set up? Just a question
1ST.....I plan on riding my sled first! At the DEC TY RIDE! and racing my buddys 05 zr900 first to see how it compares!![]()
Wouldnt you rather beat your buddys by 10 sleds instead of 1 or 2 lengths?![]()
No because SHE gets mad at me.
