need help with my 08 apex mtx cant get it to stay off revlimiter
Age
35
fox creek ab
Canada
08 yamaha apex mtx
I cant stay off revlimiter clutching is all stock secondary was set to 6 and 1 tried 6 and 3 also and still as soon as i go to wide open throttle its right to rev limiter that is on groomed trail and in 2 feet + of powder 162 2.5 paddel track any help with this would be greatly appreciated
Have you tried searching? When I turboed mine (06 model, 290 kit) I did and found a good recipe. Yamaha Blue-White-Blue spring, 0560Y Super Tip weights (almost fully loaded..), 14,5 mm Rollers, 45 degree helix, Cat Green Spring. I later changed to a dalton multi helix though. Ulmer racing should have all the hardware you need. You may already have the 14,5 mm rollers in your primary (mine did..).
