kidastra
Well as the subject implies I blew a belt during a WOT lake run, thread/yarn everywhere! took about 45 minutes to just get the yarn untangled from the clutches.
Few questions I'm hoping I can get help with.
1. why does this happen?
2. is it normal for it to happen on occasion?
3. my brp buddies (I'm the only yammy) tell me I need to adjust for a new belt, no clue what he means. I assume it has to do with my next question.
4. never adjusted or understood alignment and belt deflection, could someone give me a dummy proof "how to"
5. what should I look for after this blown belt (damages)
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Most of the time when a belt blows like that its due to heat. Remove both clutch's and wash them with hot soapy water like dawn dish soap and wash the new belt too. Blow dry the clutch's and let the belt air dry in the house. After putting the new belt on ride the sled slower for the first few miles.
Check the matel plate that covers the coolant hose to see if its loose.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
What model sled and how many miles are on it and the former belt?
kidastra
thank Apex06 I had to install the spare on the lake, was afraid to go fast after that cause I was 50km from my trailer, other end of town. I know i'll need to clean out the clutch just cause I'm 80% sure there is yarn inside still
Journeyman, I knew I forgot something. 07 Attak GT, 5000km no idea age of the belt, rode 2 short seasons with it (maybe 1500km) but I bought the sled used and didn't change the belt, checked it in December no cracks or signs of age have done about 800km since december
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
Chances are you just got an old worn belt to hot, out making hard passes on the lake. I have had 13 of the Yamaha 4-stroke sleds over the years and have only had 1 belt failure out of all of them. And it wasn't even on my Supercharged sled. Was on a 2005 2-up venture. Clean it up, put on a new belt and you should be good for many years. Have a great winter.
kidastra
Any way of keeping the heat down? Surely heat enough to blow a belt isn't normal
09apexltx
- Jan 18, 2010
- trenary / muskegon,mi
- 2009 apexltx
1984 srv 540
You can put in a vent kit on clutch side panel, i just cut in 2 oval fogzskin kit on my kids nytro, he was having belt failures, after the install no more blown belts.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Way over thinking this. Old belts on high speed runs do this, just very rarely with Yamis clutching. Get the threads out, ride and enjoy now if it happens soon again the check alignment etc
Yamadoo
Yamadoo
kidastra
figured I was, but having my brp buddies telling me I need to adjust my clutches now had me worried
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
One thing nobody has mentioned as yet, check your primary sheaves for grooves about halfway or more up the faces.....this happens frequently when people tend to cruise at one speed all the time. 8DN belts are a very hard compound and can wear these grooves in clutch faces......you can have them reground or if not too bad some emery cloth and a flat edge can clean them up.
Wonder how I might know this????
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
kidastra said:figured I was, but having my brp buddies telling me I need to adjust my clutches now had me worried
Actually, your BRP bud's were not necessarily steering you wrong.
If your new belt squeals on take off you will need to adjust the secondary. If it doesn't you are good to go after cleaning up the mess.
kidastra
Riceburner said:kidastra said:figured I was, but having my brp buddies telling me I need to adjust my clutches now had me worried
I only noticed the squeal when I let off the throttle
thinksnow
You better check the adjustment screws on the back of the secondary. I believe there are three of them. They get worn on the tips and if left too long they can ruin the threads when you try and remove them. I left mine too long and they messed up the threads. Luckily the threads were still good enough.
You adjust the belt height by adding or subtracting washers behind these bolts/screws. This helps eliminate the dreaded belt squeel.
I also remove the belt and start the sled. CAREFULLY use a green Scotchbrite pad and clean the surface of the primary. I wash the belt with Simple Green or similar product. Scrub it with a Scotchbrite pad and let dry.
Sounds like you just got full wear out of your belt. Old belts and high speed runs usually end this way.
kidastra
thinksnow said:You better check the adjustment screws on the back of the secondary. I believe there are three of them. They get worn on the tips and if left too long they can ruin the threads when you try and remove them. I left mine too long and they messed up the threads. Luckily the threads were still good enough.
is that what belt deflection is?
theCATman
- Feb 19, 2007
- WI
- Yamaha
thinksnow said:I also remove the belt and start the sled. CAREFULLY use a green Scotchbrite pad and clean the surface of the primary.
Seriously?? What DE FAWK??
You sir are gonna be known as "Leftie" in your town, as your right one will be plucked from your wrist after that clutch grabs it & won't let go until it's done. If your lucky, it will only be your hand too.
Darwin factor X10 with you.
- 10K
- 11K
