NEED HELP!!!
Deeppow16
Montrose, Minnesota
2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
I have a 2008 Yamaha nytro MTX. I'm going to the mountains in a few weeks and need to change my weights and springs. I need weights and springs for 8000-10000 ft. I cant find any charts for what amount of weight to use or what springs to use. The springs I have now are Primary-Green white Green, Secondary-Pink. Any help will be greatly appreciated.
You have the correct springs for 8 to 10000 ft. According to my book they came set up for that elevation. Also they should have empty 8FS weights and a 39 degree helix set at 1-6. If you are at 2 to 4000 ft then you would fill the 8FS weights with 13.3 mm rivets in all 3 holes, Blue Brown Blue Primary spring, and then re gear to 22/40 with a 70L chain
Thank you sir! That was everything I have been looking for. Thanks for the help!
