mulderdad
Any tips on changing the front heat exchanger on an 07 apex?
Threw a stud through the front exchanger and need to change it.
Not looking forward to it as it looks like a BIG job.
Thanks,
Rick.
Thanks,
Rick.
ecopter
Have it welded.
jf
jf
mulderdad
Its about a 2" long x 1/4" wide gash.
LazyBastard
You might not have caught that, so I'll repeat....
Have it welded.
Have it welded.
mulderdad
LOL!
That's what I'm leaning to LB and ecop.
I'm also gonna pick up a used one and change it this summer when I have the extra doh for a new track. That's a whole nother thread.
Cheers,
Rick.
Cheers,
Rick.
baknblk
Do not waste your money on the used one . I am going through this as we speak and if my memory is correct it is 13 hours at the dealer to replace . I found a guy that is draining the system and welding it while in the machine.
mulderdad
Problem I have now is the guy who welds them here will only weld it out of the damn machine.
I told him that I will remove the skid/ track and anything in his way, but he insists it has to be out!
I can raise the arse end way up and he can get right at it.
Has me ticked off! i am gonna talk to another guy tomorrow who can weld aluminum.
Cheers,
Rick.
Cheers,
Rick.
LazyBastard
You know, you can get a mig for real cheap. Practice a little, then go for it. Just think of it this way... its an excuse to get a new tool, and you can never have too many tools, and it doesn't matter if you don't recoup the cost of the tool the first time you use it.
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
i've changed them in less then 3 hours, you guys making this sound like a big deal are clueless. we have to change them on mtn, sleds all of the time from hitting stumps, etc
mulderdad
I have one arriving on monday.
I took out the old one and it sure as hell wasn't 13HRS!!!! F'n dealers are rippin people off!
Took me less than an hr to get the old one out.
Probably a total of 45 mins of actual working on it.
No track removal, no suspension removal,
no chaincase removal.
Drilled out about 20 rivets, removed the rear engine mount bolt, hoses and she wiggled right out.
Hardest part was had to chisel off on rivet head from the4 inside behind the chaincas b/c you can't get at it witht the chaincase on.
Just thought I'd share my experience.
A big thank you throttle jockey for the informative pm's.
Cheers,
Rick.
Cheers,
Rick.
baknblk
Throttle Jockey said:i've changed them in less then 3 hours, you guys making this sound like a big deal are clueless. we have to change them on mtn, sleds all of the time from hitting stumps, etc
Sounds like you are a better mechanic than rider.
Some of use maybe better at doing this and others maybe should not... this is the life of the web.
Throttle Jockey
- Dec 12, 2005
- Fort atkinson,wi
- yamaha
lol, fyi when you are a mechanic and a rider, you have to fix everybody's wrecks. not just your own. i.'m still trying to find a google that can see what is under the snow
